Hi all,
Well, I just successfully changed out my factory backup camera for an aftermarket one. The improvement is amazing! First I would like to thank Just Vlad for his Youtube video of a similar change. That gave me the confidence to remove the back bumper to access the camera. His video is at https://www.youtube.com/watch?v=XIGVhZmf-Z4.
As it turned out, removing the right side of the bumper and pulling it out enough to access the camera and wiring only took about 20 minutes, including the "nasty clip" at the very top corner of the bumper. Once the bumper was opened, the rest of the job was easy.
When I started this project, I researched what others have done and found an aftermarket camera that several people recommended. it was a "Rydeen CM2-T150B-PR HD MINy HD Ultra Low Illumination Car Vehicle Backup Camera" available from Amazon at $ 69. I bought one. Of course about a week later I saw it on Amazon for $45! Oh Well. Several years ago I added a backup camera to my 2011 Jeep Liberty and was happy with that camera, so in my initial testing on the bench, I compared that camera with my Rydeen. They were very close in both resolution and low light sensitivity, but I judged the Rydeen to be slightly better. The Jeep camera was one from Ebay for about $16 and was titled "UNIVERSAL Waterproof Rear View Reverse Camera BackUp HD Color CCD NTSC TV system".
If I had been able to compare the cameras before buying, I would have gone with the Ebay one. I'm sure I would never have been able to tell the difference once installed, but since I had the very slightly better one, I went with that. I found an unexpected problem with the Rydeen camera. It had a very long cable, enough to install in almost any vehicle with no splices. They had stickers warning that the camera was a 3.5 volt camera and to not cut the cable. There were a couple of potted cable connections in the cable and one was sure to be a voltage regulator. I powered it up, and sure enough one got warm. I cut the cable just beyond that, but was still left with about 8 feet of cable, when I needed maybe one. I didn't want to try cutting a piece out of the remaining cable as it contained both the video and the power lines, and would have been a mess to splice. My solution was to double the excess up and enclose it in a piece of split loom, which I eventually zip tied to an existing loom in the car.
I'm getting a little ahead of myself here. I decided that rather than trying to tap into the chassis harness for the camera, I would just cut off the connector from the old camera and splice it to my new camera cable. This was fairly straight forward and shrink sleeving made a nice job of it. I also decided to remove the original camera from the bracket and substitute my new camera. The old camera was fastened with 3 very tiny Phillips head screws, and I was lucky to find that I had one screwdriver bit set that went to a 000 Phillips size. I actually used the 00 size. Nothing else I had fit. I had to machine the bracket opening to make it larger for appendages on the rear of the new camera. I attached the new camera with adhesive and was ready to install it all.
I mounted the camera, zip tied the excess wire in the loom to an existing loom of wires and started to replace the bumper. Here is where I made a really stupid mistake!! In pressing the bumper back into position to secure the many clips, I accidentally pressed on the camera and pushed it out of the bracket, due to the non-fully cured adhesive! Of course the "nasty" clip at the corner had just clicked in. It really only cost me about 10 minutes to remove the bumper again, but a couple hours to clean the camera and bracket then re-attach them. This time I let them cure for an hour or so while I did something else. It then all went back together without any more hitches.
My next post will show the results of this change.
Thanks for staying with me through all this.
Here is what my poor baby looks like with the bumper partially removed:
Here is the cable after I cut off as much as I could.
And here's the final cable after placing the excess in a loom.
Here is the new camera mounted in the original bracket:
Here is the installed camera (in the center between the two license light housings) Sorry for the
glare (the 4 white bars that reinforce the bracket). The excess wires are zip tied to an original run of wiring.
