It's been brutally cold here for a few days now - near -30C at night (-20F) , and yesterday it didn't get above -20C (-4F) at any point yesterday, so things are starting to really get cold soaked here now.
So, just before heading to bed last night I do a status request via MyVoltStar (the OnStar DIY replacement) and I get an odd response from my 2011 - it's reporting that it's only plugged into a 110V EVSE (despite being plugged into an L2) and that the battery is sitting dead despite having been plugged in for most of the day after I got home from an early morning drive. It also shows the car is only using 2A which wouldn't even be enough for the battery heater, much less charging.
So, I go outside, climb in, and hit the power button...and low and behold!
So, I pull up MyGreenVolt and sure enough, the battery is sitting at -5C (23F) which is apparently below the magic temperature.
I discover that my EVSE has apparently stopped working properly for some reason, so I switch to my wives L1 EVSE and it starts drawing 1500W immediately, so I know the battery heater is working.
Sure enough I plug the other EVSE into my wifes Volt, pull up OnStar, and it's reporting it's showing only L1, and it doesn't actually seem to be charging at all despite the green dash light going on. I disconnected it and brought it inside for the night and left my car charging on the L1. Something's wrong with the L2...
This morning everything was back to normal with the car - the battery is warm, and it charged up without any issues.
I brought the L2 EVSE back outside, plugged it back in, and it seems to be working normally again. Apparently it was too cold outside even for it!
