That's dangerously underpowered... I would take it back and get the regular 110kW configuration.I got the 8.9kW option on my 2017 Volt
The 2016/17 does get a bonus. It pushes 120kW when you take to the spurs to it.That's dangerously underpowered... I would take it back and get the regular 110kW configuration.
I can probably get 100 miles of EV range indicated. One day when the conditions are right, I'll give it a shot. As most people know, the end result of 87 miles indicated was much less than the actual miles driven.Confusing title not withstanding, 87 miles per charge is great for a Gen 2 Volt.
Having said that, Ari C (Hypermiler Extremus) managed to eke 81.8 miles out of his 2012 Volt with the original 16kWh battery, using about 9.8kWh to do it! Early Gen 1 Volts however do not display more than 50 miles estimate (later models can go up to 60, I believe). Looks like there are no such limits in Gen 2 Volt .. or maybe Ari C will find out. I believe his wife got a Gen 2 Volt.
Right! Pump up your tires to 60psi and drive slow, 23 MPH, level ground, no wind, windows up, everything off in the car.I can probably get 100 miles of EV range indicated. One day when the conditions are right, I'll give it a shot. ....
Sometimes my commute to work is 2 hours and it gets boring when that happens. The 87 indicated miles wasn't displayed after charging overnight, it was displayed after driving 42 miles to work.But it's +2 hrs of your life, for what?
Ha, ha - he must have driven a good portion of those first 42 miles downhill and only depleted one-third of the battery (4.66 kW) so it displays 87 miles AER when he arrived at work.What's the highest indicated mileage you've ever seen for your EV range? View attachment 129249
Don't forget to drive downhill both ways!Right! Pump up your tires to 60psi and drive slow, 23 MPH, level ground, no wind, windows up, everything off in the car.
Anybody can do it. But it's +2 hrs of your life, for what?
What's with the title to this thread?
For what?Right! Pump up your tires to 60psi and drive slow, 23 MPH, level ground, no wind, windows up, everything off in the car.
Careful with your units... you keep using kW when you mean kWh (the equivalent of saying "horsepower" when you mean "gallons of gas").Ha, ha - he must have driven a good portion of those first 42 miles downhill and only depleted one-third of the battery (4.66 kW) so it displays 87 miles AER when he arrived at work.
When did he run out of battery on the way home? Immediately after driving 10 miles uphill?
You'll consume 1 kW for every mile you drive up a 7% grade. I know, been doing it for 3 years.
Must be some commute if you drove 42 miles to work and arrived with a full charge still remaining in the battery and less than 1 gallon of gas used!The EV range is almost never correct. The gas gauge is the same way. I understand why but I'd much rather have gauges that show kW remaining for the battery and gallons remaining for the gas. Just give me the raw numbers and I can figure out the rest.
I think .3kW's were used on the way to work and gas was used for a lot of that mileage. On the way home, probably 55 miles were electric and yes, most of it was uphill. Work is 6 feet above sea level and home is around 1000 feet above sea level.Ha, ha - he must have driven a good portion of those first 42 miles downhill and only depleted one-third of the battery (4.66 kW) so it displays 87 miles AER when he arrived at work.
That's the point. It's a crappy way of showing the driver how much mileage is left. If you drive on flat highways, your climate is the same all year round and you have the same driving habits all of the time, the estimated miles remaining will be very accurate.Must be some commute if you drove 42 miles to work and arrived with a full charge still remaining in the battery and less than 1 gallon of gas used!
So, show us what you can do with the raw numbers... your photo shows 10 green bars of power, i.e., 100% of the ~14 kWh of full-charge available power, and 9 blue bars of gas, or 90% of the 8.9 gallon full gas tank capacity (= 8.0 gallons). If your ev range is not 87 miles, nor your gas range 297 miles, what is it?
Yes. That's because the estimated miles are based on the past driving cycle and the current driving cycle. The estimated mileage continually updates as you're driving.By the by, our friend Ari C drove his wife’s Gen 2 Volt 114.0 electric miles using 14.4 kWh of power (7.9 mi/kWh), and was rewarded the following day with a full charge ev range estimate of 85 miles.
There is a distinct difference between the full charge, or start of day, range estimate and the on-the-fly estimate made after you unplug and start driving.Yes. That's because the estimated miles are based on the past driving cycle and the current driving cycle. The estimated mileage continually updates as you're driving.
When I left home, my estimated EV mileage was 46. When I arrived at work it was 87. Ari had the opposite experience. His previous driving cycle had a huge amount of miles and that's why his full charge was 85 miles. However, both of our Volt's charged to ~14.4kWh. That's why having a gauge that displayed kWh remaining would be better, IMO.
