Thats only when a call comes in you can still turn the fan up.Hi,
Has anyone discovered a way in the Gen 2 to disable the lowering of the HVAC fan speed when a phone call is received? I reviewed the settings and options and couldn't find anything.
Thanks,
I too wish I could find a way to suspend that "feature" as I have received far too many calls right after I get into a boiling car and want the AC left alone.
Agree this is quite annoying when it's hot or cold out. The concept is great, but it's over kill. You can turn the fan back up, but it never reaches the same level. This feature ought to go away, and if you can't hear a call, you can manually turn down the fan.Thats only when a call comes in you can still turn the fan up.
Yes, my 2018 works that way when using the cell phone connected via Bluetooth.for gen-2 - does it work that way for both build in onstar phone use AND external cell phone using bluetooth
I believe so. I turned the fan up all the way today, set it to max, and then received a call via Bluetooth. The fan speed went way down.If the HVAC fan speed has been set manually will an incoming phone call still low the fan speed?
Thanks. I don't mind when the fan speed lowers during phone calls. I precondition my Volt summer and winter so the cabin is already comfortable when I get in the Volt.I believe so. I turned the fan up all the way today, set it to max, and then received a call via Bluetooth. The fan speed went way down.
