1 - 4 of 4 Posts
I had a little incident today and broke the plastic element that covers the lower turn signal on the passenger side of the front bumper:
Does anyone know if this is a part I can get, and how to replace it if it is?
I checked gm parts direct and could not find the element as a separate part in the bumper diagram.
Any help is greatly appreciated
Sent from my iPad using Tapatalk
· Administrator
Completely remove the bumper fascia to get to the backside fasteners.
In your case either ebay and even amazon have this part avail online or you could just source from your dealer service dept. The GM part# you need is 22810494 pictured above for the RH side. 22810493 would be for the LH side.
As Steverino kindly pointed out, you have to drop the front plastic bumper on the Gen1 in order to replace this which isn't very time consuming or hard. I've had the bumper on my Gen1 off a couple of times. Good Luck!;)
1 - 4 of 4 Posts
