https://gm-volt.com/2015/02/20/gen-2-volt-transmission-operating-modes-explained/
https://www.youtube.com/watch?v=kCdUwUCLPB8
The gen2 transmission has two planetary gears, and is continuously variable. In CS1 (and CS3 mode) the ICE transmission "gear" is magically controlled by the speed of the electric motor which allows the ICE gearing to be continuously variable. They call this "eCVT" since the gear is being electronically controlled rather than a mechanical CVT. In CS2 mode ICE is directly coupled to the wheels for maximum efficiency to minimize transmission losses.
Ignoring the two electric motors which are the cost of having an EV, how much more complicated and/or more expensive is the two planetary gear transmission setup in the Volt than a convention automatic transmission in say a Chevrolet Cruze? Which would be expected to last longer, conventional transmission or Voltec eCVT?
Also, what other hybrids use two planetary gears? Honda? I think the Prius uses one planetary gear for their hybrids, but maybe that changed with the gen4 Prius.
