I went outside yesterday, lifted the hatchback lid, and grasped the black plastic housing of the right-side stop assembly, and gave it a good strong shake. Hark, a rattle! I did the same for the left side: no rattle! Just a little wiggle. So I got a hammer and gave the right side assembly's pins a couple of light taps. No change. I didn't want to crack it, so I stopped there. Then I had my BRILLIANT IDEA.
First I used two toothpicks to pry the plastic stop assembly as far out as it would go from the hatchback lid's metal frame (opening the gap between the metal and the plastic assembly as much as possible). Then I put masking tape onto the metal surrounding the assembly. Next, I squeezed Shoe Goo into the exposed gap, being careful not to get any onto the adjustable stop, wiped off the excess from the assembly surface, and removed the toothpicks and the masking tape. I gently closed the hatchback lid (but did not fully close and lock it) and let the Shoe Goo cure all night. This morning: total, unambiguous success! Driving around was a silent wonder again -- no rattling, and also no clicking from the bad CV joint that was fixed yesterday -- just smoothing-driving silence!
Probably silicone sealant would work as well as Shoe Goo.
