1 - 4 of 4 Posts
Can somebody explain how the climate control works when you "remote start" the car? Do I need to set anything? Does it just use the last settings from when you turned the car off? I'm wondering how it knows what temperature to set and also how it knows when to turn on the heated seats and steering wheel.
I have noticed that the driver's seat heater will come on somewhere around 40 degrees F. I have not seen the steering wheel heat come on during a remote start, but I have only been through one mild winter season so far.
From the 2017 Manual page 37:
During remote start:
. The climate control system will
typically default to the last
climate setting. If the fan is off or
if eco and MAX are not selected,
the air conditioning or heat will
turn on as needed. See
Automatic Climate Control
System page 157.
. If equipped with heated seats,
and the vehicle personalization
setting is enabled, the remote
start auto heated seats may also
come on. See Heated Front
Seats page 54, and Vehicle
Personalization page 141.
. If equipped the heated steering
wheel may also come on. See
Heated Steering Wheel page 96.
. The rear window defogger will
turn on during colder outside
temperatures.
. Selecting Defrost during colder
outside temperatures before
shutting the vehicle off will help
windshield clearing.
. Shutting the vehicle off in eco
mode without1selected will
minimize the impact to electric
range. Shutting the vehicle off in
other modes will maximize
heating or air conditioning.
. The engine may start to provide
energy for heating and cooling,
independent of the vehicle being
plugged in or completely
charged. Engine Assisted
Heating operation, if available,
can be personalized. See
“Engine Assist Heat Plugged In”
under Vehicle
· Moderator
I just leave the climate controls set to 'auto' and let the car take care of it. I do have the engine-start option disabled when plugged in since I don't want it to fire up in my garage.
One of these days, I'll have a fully electric car and won't have to worry about gas/oil/engines any more. I have already replaced all my small gasoline engines with electric or battery-electric versions. One more to go!
1 - 4 of 4 Posts
