Not having a quick reply I went out and looked at the time till a full charge for plugged into the regular outlet then unplugged and put it to my 240 outlet. Indeed Im getting much faster charging through the adapter. I will check out your other methods in the am. thanks. DD...And it will charge twice as fast as with 110v
Every home has to verify its utility voltages. Some may be below 220 VAC and some may be higher than 240 VAC, as in my case which is 246 VAC because my pedestal-mounted utility transformer is across the street (less than fifty feet) from my meter with a very low feed resistance, and I am one of the four home getting power from it. Higher voltages allows lesser currents for the same load, so my breakers last longer (42 years up to now). And that same transformer can supply me a second 240 VAC and 100 A feed for my own 20 kW DC charger if I buy two BEVs in the future.If you're in North America and you're in the 21st century, I can tell you you're *not* charging at 220V.
You're charging at 240V.![]()
I've given up trying to teach people that there's no such thing as 220 or 110.If you're in North America and you're in the 21st century, I can tell you you're *not* charging at 220V.
Yes, actual might vary, but it's nominal 120/240VEvery home has to verify its utility voltages. Some may be below 220 VAC and some may be higher than 240 VAC, as in my case which is 246 VAC because my pedestal-mounted utility transformer is across the street (less than fifty feet) from my meter with a very low feed resistance, and I am one of the four home getting power from it. Higher voltages allows lesser currents for the same load, so my breakers last longer (42 years up to now). And that same transformer can supply me a second 240 VAC and 100 A feed for my own 20 kW DC charger if I buy two BEVs in the future.
condos and apartments run on 3 phase power that is 208 volt , ive seen that 208v number at 220vIf you're in North America and you're in the 21st century, I can tell you you're *not* charging at 220V.
In case you don't know, it's all about power. Power is current times voltage. You sound like you're adapting the stock gen2 EVSE for L2 usage, so you're going from a max of 120V x 12A = 1.4 kW, to 240V x 12A = 2.8 kW. Literally exactly twice the power, so you should charge about twice as fast. Note that a "true" L2 EVSE would go higher than the 12A max of the stock unit, usually 14-15A, giving 3.3 - 3.6 kW, which would charge even faster, but may not be worth the cost above adapting the stock EVSE like you're doing just for that extra 20%.Not having a quick reply I went out and looked at the time till a full charge for plugged into the regular outlet then unplugged and put it to my 240 outlet. Indeed Im getting much faster charging through the adapter. I will check out your other methods in the am. thanks. DD
