Some things to consider:
Will the Bolt be your last EV? If not, also check prices on 40 amp EVSE's too. If there is no difference, get the 40. A 50 amp breaker in your panel for 240vac cost the same as a 40 amp breaker, and the 50 amp breaker will support a "14-50" NEMA plug in connector. This is the most common RV/EV high power wall plug.
Will you ever go camping or travel cross country in your Bolt? If so, get an EVSE that is removable (like a JuiceBox or Clipper Creek) and has a 14-50 end on it. This way you can charge at RV parks quickly.
Select a Time of Use electrical plan if available, and set your charging time to your super off peak rate time. Now, program everything else in your house that you can that uses power to that same window. Like pool pumps, washing machines, driers, etc.
NOTE: I refer to normal house power as 120vac and 240vac, since that is how many volts most modern homes are supplied with. You can hear it called 110, 115, 220, 230 as well.
NOTE2: If you are using Southern California Edison, there is an additional $450 rebate you can apply for besides the Federal and State rebates.
