Yesterday I traveled 3.5 hours to the nearest dealership with a new Volt in stock. They gave me half an hour with it and I spent most of that trying (and failing) to figure out how to get it to run on battery alone. My obviously mistaken understanding was that the car drove on battery alone for the first 85km and then the battery would kick in to maintain power. I could choose between normal, sport and mountain modes (hold was greyed out) and I kept it in normal. The infotainment display showed me the flow diagram. Rarely, it would be running on battery alone, but usually it was showing battery and motor, and often just motor. The only times it was battery alone was on very flat roads with zero to negative acceleration. I reset the trip before starting and at the end of my drive and, well, see attached photo.
Was something wrong? Was the battery very low? The guy said it had a full charge, but to be honest I didn't know what the display was telling me. Is the Volt only good on battery only for cruising on very flat roads? Was this normal for the motor to be running so much?
[Edit] ok, after reviewing my photo... that is out of battery, isn't it? The 5.1l/100km (46mpg) seems consistent with that, right?
