HELP! I am desperately searching for GM Part# 24285319 - Automatic Transmission Wiring Harness (not available in CANADA - back-ordered for months). I am car-less without this part.
Thanks for your reply and suggestion Stephan but a wreaked Volt would probably have the faulty harness part we're trying to replace.dmtanner,
Just buy a used harness from a wrecked Volt! I needed the charge port (was ripped out) and it was not available in Detroit new. Instead of parking my car forever I bought a used charge port assembly, from Canada by the way. Plugged/bolted it in myself and I was good to go.
2017 EVSE charge port ripped out! DIY new port +...
Guy's, Add insult to injury! an ICE car parked in the reserved and marked charging space so I parked next to them in an open regular parking space. I pulled the charge cord to reach my car and it was looped under their car. When the offending car left, it hooked the charge port cord and ripped...www.gm-volt.com
Stephen
I am not a mechanic and apparently replacing this part requires a lot of removal of parts to access it.dmtanner,
I would still try that route, if part is no good then return it! Worst case I would try to fix the harness myself or get it "rebuilt" if even possible. I love driving my Volt and pulled it from the dealer after three weeks of waiting for the part to "magically" appear! My Volt would still be parked at the dealer collecting dust today 3 months later! Question is how long will your car be parked waiting for parts? Proactive solutions can get most jobs done in a timely manner, at least that has been my experience!
Stephen
" when you're from NJ NO is not an answer, its just the beginning of a negotiation "
Thank you but this is not the part I am seeking (24285319) nor the part its replacing (24264229 or 24278162)...![]()
GM HARNESS 22972414 GM 22972414 | eBay
Find many great new & used options and get the best deals for GM HARNESS 22972414 GM 22972414 at the best online prices at eBay! Free shipping for many products!www.ebay.com
Buy this one? A bit more money, but hey at least you'll get it.
That is assuming they have it in hand.
I have it back ordered from a number of sites. Most give an estimate of end-of-June / early July for availability.Hi, Any luck with the part?
I am looking for the same part.I have it back ordered from a number of sites. Most give an estimate of end-of-June / early July for availability.
Are you having the same issue (RE: https://www.gm-volt.com/attachments/chev_tsb_pic6330-pdf.176851/ ) ? Starts in non-EV mode, shakes violently?I am looking for the same part.
Yes, the same issues. 2017 VoltAre you having the same issue (RE: https://www.gm-volt.com/attachments/chev_tsb_pic6330-pdf.176851/ ) ? Starts in non-EV mode, shakes violently?
