Hi all,
Here in the mid-Atlantic, the temps went from about 70-80 on average over the past month down to the high 40s-low 50s these past few days.
Having bought my car in May, this has really been the first time I've felt the need to use anything more than the seat heaters.
When I set the temp to 70 and put it on auto, eco mode, the vents put out cold air. The drive was about 30 minutes, but it did not warm up at all on the ride home. In contrast, my home heat set to 67 was producing heat you could actually feel coming out of the vents.
The outdoor temp was 48 at the time, so the interior temperature was likely similar. The car had sat empty for 3 hours in a parking lot prior to the drive. I understand that car heating systems, and particularly the Volt's work differently, but I really got no heat at all.
This is not really an issue for me in the fall weather, but my wife really likes having tangible amounts of heat come out of the vents, and I can't blame her. If this is something broken, I'd like to get it fixed before temps drop into the 30s.
Is this fairly standard behavior for eco mode? Do I need to put it on MAX to get any sort of heat you can actually feel out of the vents? Does it just take 40+ minutes to heat up? Or is this a sign that something is broken in the heating system?
Any and all input appreciated.
