1 - 4 of 4 Posts
Is there any new type of air conditioning planned? or will the a/c run via a rotoary compressor that's driven by the gasoline engine?
What about heat? Can the interior be heated from the batteries or must the gasoline engine be running?
I only ask because about 85% of my driving around here usually involves either heat or a/c.
Low power efficant electric heat and a/c system like a hair dryer only bigger. The coil you reverse the polarity it gets cold and so it cools the cabin that's how I under stand what I read. Any ways It's on the 2007 auto detroit auto show page it's still up you can search Chevy Volt Heat and A/C lots of cool stuff comes up
Most likely a heat pump
A heat pump can reverse and put heat or cold into the air inside the car. That would be the most efficient system.
A Peltier thermoelectric sounds nice in theory, but the efficiency is so bad it would take the entire output of the battery pack to run the a/c for about an hour.
1 - 4 of 4 Posts
