Just curious if anyone else has experienced this before:
I will precondition before leaving home then switch to fan only mode to help keep the windshield from fogging. With just using the heated seat and steering wheel heat I'm good to go. However after several minutes of running in this mode I will suddenly get full heat coming out of the system with ECO/MAX off. I end up turning the system off and waiting a minute or to before turning back on before it's fine again. This happens almost every day. The display clearly says "fan only mode". Is this normal and I just don't understand the system? Thoughts?
