1 - 4 of 4 Posts
My driver side headlight is stuck on bright. The baffle to dim the headlights is stuck. No click on that side. What's the fix?
Separately fused, perhaps remove its fuse for a second while it is on. Might unstick it.
I'll try that.
Also need to get the multimeter out and see if there is power to the solenoid or if the shutter is just stuck.
I'd imagine the solenoids would be normally unpowered when down, since that's the position they're in most often and longest. I can HEAR mine move, and apparently you can too, so "just stuck" looks like a very likely case. WHY it is stuck is a whole 'nother ball of speculation, though. :)
1 - 4 of 4 Posts
