Great news! I finally got my new volt from GM and it drives perfectly! On the other hand..
My new car had to have a depressurizing vent replaced under the hatchback because when you close it, the hatch does not close fully, leaving the hatch light to stay on. Even after the vent was replaced, the problem re-occurred less than 2 days later. Even using force to close the hatchback did no good, only after letting it drop could you then push down to make it fully latch.
I went to the chevy dealer today and was initially told that this was normal. I had to show the tech several other volts on their lot before he agreed that it might not be normal as every single other car closed with zero assistance other than gravity pulling the hatchback down. After deciding to take the arm bars off another Volt, it seemed to work for a moment.. that was until I put an item into the hatch (that wasn't blocking the hatch in anyway). The moment I put something into the hatch... it continued to do the same exact thing, not closing fully, leaving the hatch light on. The tech verified that nothing was in the way to prevent the hatch from closing, but stated that just something being back there was changing the air pressure inside the car. I explained that that scenario never happened in the previous car, and it had the same things + groceries and always closed on its own, using gravity to do so.
I ultimately left aggravated. Does anyone else have an issue with their hatch, that they have to try and slam or even assist the hatchback to close?
