Not sure where you would fit nearly double the battery without removing the gasoline engine.I wonder if it would be possible in the future to put in a larger capacity battery to get longer range. I think 200 km (124 miles) would be more ideal for this car
Think they mean the main car battery.I have replaced the batteries in both my FOB's
I was thinking maybe an improved battery in the same size, if possible? Perhaps a solid state battery in the future..Not sure where you would fit nearly double the battery without removing the gasoline engine.
Bolt's (really, pretty much all BEVs) battery is much better packaged, fitting over 3x the capacity in less "intruding into the cabin space". I've always fantasized about a gen3 Volt with half or third of a Bolt's battery pack in it (in floor)... tons of range, no loss of cabin space, 3 real rear seats, etc.Not sure where you would fit nearly double the battery without removing the gasoline engine.
Now you have. My early 2018 experienced a gradual high voltage battery failure about 4 months after purchase. GM provided a new battery at no cost. This took almost two weeks to ship and install. I had a loaner Malibu, so that was fine.https://insideevs.com/zero-first-ge...ks-replaced-due-general-capacity-degradation/
In addition to this story, I have not heard of any forum member who had to have a full battery replaced.
Just curious — did they say what caused the systemic failure of the battery pack?Now you have. My early 2018 experienced a gradual high voltage battery failure about 4 months after purchase. GM provided a new battery at no cost. This took almost two weeks to ship and install. I had a loaner Malibu, so that was fine.
Nope. My local dealer opened a ticket with GM Technical Assistance Center, and sent them diagnostic logs. The TAC made the call that the battery was bad, and I doubt the local dealer understands what happened either.Just curious — did they say what caused the systemic failure of the battery pack?
A few out of 200,000. Free under the 8 year/100k mile (10 year/150k mile in CA) warranty. Outside the warranty DIY or via a dealer, costs will varywidely.Just wondering if anyone has had to replace batteries in a Volt and if so, how much did the batteries cost?
No, nor do I expect them to ever be available. Used from auto salvage yards are available.Are aftermarket batteries available yet?
GM's pre-production testing went to 200,000 miles (2X warranty) with no issues. Unlike air-cooled battery's from Nissan and others, GM's are aggressively (Dextron) water cooled to keep them from the degradation caused by heat, a known battery killer.Any data on how long the batteries last?
