Sounds a little like my LED headlights that won't melt snow. Oh well, otherwise they're pretty okay.Currently thawing out the barn well which has buried pressure tank and demand switch which sits at the bottom of a vertical PVC pipe about 5 feet into the ground...because someone had installed an LED bulb in the emergency light that sits in the pipe instead of the INCANDESCENT lightbulb which generated enough heat to keep the switch frost free...![]()
The farm in upstate NY where I grew up we had one hell of a time with the barn water supply in cold weather. We finally built an out-building with a tiny natural gas heater in it over the main valves and inflow which would keep it all above freezing...period. LOLCurrently thawing out the barn well which has buried pressure tank and demand switch which sits at the bottom of a vertical PVC pipe about 5 feet into the ground...because someone had installed an LED bulb in the emergency light that sits in the pipe instead of the INCANDESCENT lightbulb which generated enough heat to keep the switch frost free...![]()
My outdoor water hydrant is frozen even though the actual valve is supposed to be deep underground. I’ve been hauling water from the house to the horses using two empty gallon iced tea bottles. And the wife insists that I keep our outside working dog in the garage during this cold, he has broken the 3rd set of garage door sensors. Earlier this evening I found him at the barn, and he looked at me like “man, it’s f***ing cold, please let me in the warm garage”The farm in upstate NY where I grew up we had one hell of a time with the barn water supply in cold weather. We finally built an out-building with a tiny natural gas heater in it over the main valves and inflow which would keep it all above freezing...period. LOL
Well, if you do like i do on the farm buildings...I put my door sensors together up about 8 feet in the air...My outdoor water hydrant is frozen even though the actual valve is supposed to be deep underground. I’ve been hauling water from the house to the horses using two empty gallon iced tea bottles. And the wife insists that I keep our outside working dog in the garage during this cold, he has broken the 3rd set of garage door sensors. Earlier this evening I found him at the barn, and he looked at me like “man, it’s f***ing cold, please let me in the warm garage”
The problem is that the building contractor ran the wires in the wall, and they pop out about a foot above ground.,,,,though you’ve got me thinking I could easily staple them down so the dog can’t snag them and pull them out. Similarly, maybe just forego the system and have the two sensors pointing at each other sitting on top of the motor. Interestingly, I thought of bypassing the whole system by just connecting the wires togetherness the motor, but apparently there is some special transmit/receive waveform that makes these garage door eyes work. So every time the dog tears into it and rips the wire of right at the molded base, it’s another $40 down the tube.Well, if you do like i do on the farm buildings...I put my door sensors together up about 8 feet in the air...![]()
Wiremold steel wire channel is attached with screws, can't be ripped out, protects the wires. https://www.amazon.com/Wiremold-BWH1-Metal-Raceway-Channel/dp/B000VYOGZUSo every time the dog tears into it and rips the wire of right at the molded base, it’s another $40 down the tube.
This brings back memories of something I experienced a year ago.I texted him and said make sure you use your washer fluid and put in some stuff made for -20F. Did he listen? Nope. Did it freeze his lines by the time he got to our house? YUP, Kids ����
The problem is the that the eye sensor protrudes out attached to the garage door rails. So the wire dangles in mid air. i’m Thinking about something like a 3 sided box with a cap over it. This way it’s all covered up.Wiremold steel wire channel is attached with screws, can't be ripped out, protects the wires. https://www.amazon.com/Wiremold-BWH1-Metal-Raceway-Channel/dp/B000VYOGZU
Maybe something like 3-gang electric box, or one made of wood.i’m Thinking about something like a 3 sided box with a cap over it. This way it’s all covered up.
If you have high water table, the hydrant might not drain and then it would freeze.My outdoor water hydrant is frozen even though the actual valve is supposed to be deep underground. I’ve been hauling water from the house to the horses using two empty gallon iced tea bottles. And the wife insists that I keep our outside working dog in the garage during this cold, he has broken the 3rd set of garage door sensors. Earlier this evening I found him at the barn, and he looked at me like “man, it’s f***ing cold, please let me in the warm garage”
The well is 150 feet down, but I don’t know how low the hydrant goes.that might be it. I’ve been thinking of wrapping the to[ with heating tape like they used to at a stable where we used to board our horses, but if what you say is true, then wriapping would be futile.If you have high water table, the hydrant might not drain and then it would freeze.
Perfect. Though I’ve rarely purchased anything from an infomercial
