1 - 20 of 21 Posts
Hi
It's been a while since I've bought a used car.
We leased a 2017 Volt LT for 3 years, returned it a few months ago, now have decided to buy a used one. We want a Premier with all the safety features.
There are 2 used ones at a dealer:
32k miles, clean carfax, 15990
36k miles, 2 non-serious but reported accidents, adaptive cruise, blue ($$), 16990
I'm leaning towards the first.
I have an ODB reader that I could probably use with the right app to do a battery read on a cell-by-cell level.
Other things I should do to get it checked out? It is being sold by a chevy dealer...when I have bought used cars before, I would take it to an independent mechanic for an inspection...are there independent mechanics for Volts?
What color is the first one? It will make all the difference in the world (at least if I were buying it).
What years are these volts?
I don’t think there are many independent mechanics for volts. Any mechanic can check out the typical stuff, but you probably need a Chevy dealership with a voltec certified mechanic to plug in and give you feed on the EV portion of the car.
Discussion Starter #4
My bad. Both are 2017. The first one is black.
2013 Volt
I'd wait for one without accidents and with ACC. If you are spending that much, why not make sure you get ACC? It only has to save your life one time to pay for the difference and it greatly helps resale.
Discussion Starter #7
I don't understand how ACC can save your life. Maybe I'm not understanding how it works. I watched some videos of it and it seems like you basically let the car drive, and is probably best on a highway....it's not autopilot (ala Tesla). Teach me!
I know ACC vs Non ACC has been beat to death on other threads, but my personal opinion, I would not have another car without it, or some form of it. The ACC itself might not save your life versus the forward auto braking, but the convenience of not having to brake or disengage cruise when the car in front of you slows is priceless. My commute to and from work is not stop and go traffic, but its usually fairly heavy, enough that it is actually hard to use normal cruise control because you have to constantly brake. With ACC you set your speed and let the car maintain proper distance, it's a no brainer.
Discussion Starter #9
Thanks for that explanation. I guess some of this may depend on what we're using the car for. It is not a commuter car. It would be for around town and long trips.
you would want it for long trips. I used to travel a bit for work and loved it when rental cars had this feature. Lane departure warning is also interesting, though sometimes a nuisance when driving on a windy mountainous road where you are intentionally trying to hit your marks using the racing line on curves.
I couldn't agree more. If you regularly will be driving long-distance, then ACC is a beautiful thing. You will be significantly less stressed & tired at the end the end of the trip. If one only drives around town, then it's not worth the additional expense. I wouldn't buy the Volt without this option. I use ACC almost daily.
  • Like
Reactions: digitaljem
Any good mechanic can give you an opinon, the Volt still has conventional brakes, tires and suspension, even an engine to listen to (to start, just open the hood while On). Use MyGreenVolt app to measure cell variance, <.02 is good, >.05 is walk away. An accident repair can be done properly, with no long-term issues, but many times it'll just never be as good again. An experienced driver will always outperform a digital assistant, but these systems can help us failure prone humans sometimes. Eventually, us humans may not have much choice. Good luck on your search, egizzi.
Discussion Starter #13
Thanks everyone for your helpful guidance....
If I am getting ACC, there are 2 cars locally...
1) 18.5k, 28k miles, one owner clean carfax, local green auto dealer, red exterior, brown/black interior (including brown dash)
2) 18k, 34k miles, one owner clean carfax, local chevy dealer, white exterior, black interior, Certified used car
The certified benefits:
  • 172 Point Inspection
  • Warranty Deductible: $0
  • Transferable Warranty
  • 24 months/24,000 miles (whichever comes first) CPO Scheduled Maintenance Plan and 3 days/150 miles (whichever comes first) Vehicle Exchange Program
  • Roadside Assistance
  • Limited Warranty: 12 Month/12,000 Mile (whichever comes first) from certified purchase date
  • Powertrain Limited Warranty: 72 Month/100,000 Mile (whichever comes first) from original in-service date
  • Vehicle History
Given the certified benefits relative to the above cars, any thoughts on the value of a certified pre-owned car?
egizzi,
If you buy a used 2017 Premier with comfort packages 1 and 2, ACC has to be added separately when car was originally ordered new. The bowtie symbol in the front grill will be flush. unfortunately ACC does not come automatically like it does in a Ford Fusion Energi Titanium package. I made that mistake when I bought a used 2017 Premier with comfort packages 1 and 2 w/o ACC. ACC seems to be pretty rare in Volts.
Stephen
  • Vehicle History
I'd go with #2. I just picked up a 2017 Premiere fully loaded with 33.5k miles for 16.2k in white with black interior. Still under original factory until January so I hope to get a few issues addressed like shift to park. In your case 18k for a certified car is not bad and I'm sure you can work them down a bit from there. Given some of the problems some Volt owners have experienced, getting the additional warranty coverage may be worth the few additional dollars for a bigger window of time to address problems that arise. Good luck!
#2, get the CPO, but make sure it has ACC, I fought long and hard with an online dealer who claimed their car had ACC when it did NOT.
Exact same situation. Had 2017 Volt LT 3 year lease. Bought a used one. Waited about 4 months until the one we bought surfaced. 2018 Premier fully loaded. No accidents. 19K miles. Was not put into service until March of 2019 so lots of warranty left. About 50% depreciation from new. Car is awesome. Don't settle. Be patient. You'll find one.
Hi
I just bought a 2018 Volt Premier with all the bells and whistles at a Chevy dealer here in Fla.. It had 8041 miles with a clean CARFAX and it's a 'GM Certified' used car and paid 22K for it.. I'd look for an 18 (I've read some contradictory information on the 17's) with low miles.. I'd also say be willing to travel for a good used car, I drove from St. Augustine to Clearwater to get this one (220-miles)..
nice find. What color is it? As for all the bells and whistles, did it have the much desired ACC?
Hi
My wife has a 2017 Red Premier. If you are getting a Premier I would suggest getting one with ACC. I would never by another new car that does not have ACC. My 2018 Bolt Premier does not and is its biggest fault.
1 - 20 of 21 Posts
