Just to be clear, light housings designed for halogens are not going to have the correct beam patterns when fitted with HID capsules:
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
Mine will be here any day. I'm really looking forward to it. Did you install the HIDs yourself?
I suggest going for the harness. I used one on my '12 but not on the '13. After noticing a lot of flicker at times, I added the harness and they are solid now just like the first. Plus no worry about damaging the stock circuit either. Not saying the will get damaged without one...just more peace of mind IMHO
Those who can do, do. Those who can't do, teach. I have a really nice HID set up from Morimoto, 35 watt, 5000K and the bottom line is that I can see much better at night with those lights than I could with the stock set up. Don't go trying to tell someone that has done this modification, that we cannot. I don't really care about physics, patterns or any other mumbo jumbo. I care about real time results. My results are really good, much better than stock. Now are there some cheap HID's out there that do not work as good, absolutely. But for those of us that have real time results that are good, don't try to tell us, that they are not, and we only think they are. I also have never had someone flash their lights at me, so I know I am not blinding anyone.First, I made no mention of cut-off. Projectors do indeed have a plate that blocks light from going higher than a specific height. What I said was beam pattern. A headlight is not designed like a flashlight. And a flashlight with a cut-off plate does not make a good headlight (even a really strong one).
Thanks for all the info again.
Got my DDM 35 watt 5000k HID's installed.
They look so much better. No more yellow.
Could you provide a link to where you purchased them?
I am interested in doing the same...
Thanks!
First, I made no mention of cut-off. Projectors do indeed have a plate that blocks light from going higher than a specific height. What I said was beam pattern. A headlight is not designed like a flashlight. And a flashlight with a cut-off plate does not make a good headlight (even a really strong one). The shape and distribution of intensity of light is designed with driving in mind. The arc of an HID arc capsule will never be able to accurately match the way a filament will throw light on the ground.
I'll add an additional link from the same site that discusses HID vs Halogens. It discusses some of the physiological aspects how we see using headlights at night, especially with respect to lighting distribution.
http://www.danielsternlighting.com/tech/bulbs/Hid/disadvantages/disadvantages.html
All this said, do with the information what you want. I only seek to inform.
Gee, and I thought this is a forum for presentation and discussion of ideas without fear of personal attack. If we want to maintain the usefulness of this forum we should keep it free of demagoguery.Those who can do, do. Those who can't do, teach. I have a really nice HID set up from Morimoto, 35 watt, 5000K and the bottom line is that I can see much better at night with those lights than I could with the stock set up. Don't go trying to tell someone that has done this modification, that we cannot. I don't really care about physics, patterns or any other mumbo jumbo. I care about real time results. My results are really good, much better than stock. Now are there some cheap HID's out there that do not work as good, absolutely. But for those of us that have real time results that are good, don't try to tell us, that they are not, and we only think they are. I also have never had someone flash their lights at me, so I know I am not blinding anyone.
I realize you say you are only trying to inform, however you may also be causing someone who could benefit from this modification to not do it, based on the theory that it does not function as desired, when in real time it does if you choose a good company and kit.
Gee, and I thought this is a forum for presentation and discussion of ideas without fear of personal attack. If we want to maintain the usefulness of this forum we should keep it free of demagoguery...
KNS
I took your advice.It is. But since this thread is about MY HID's, can we stay on topic? I appreciate the info, but thanks for taking away my thunder.
If you would like to start your own thread on this topic, be my guest. Thanks.
I apologize for the threadjack. I didn't intend for this to become a full discussion.It is. But since this thread is about MY HID's, can we stay on topic? I appreciate the info, but thanks for taking away my thunder.
