1 - 5 of 5 Posts
So, this happened three times this week. I preconditioned the car in the morning like normal (its been in the high 20s-low 30's). I come out to the car, unplug, hop in, and hit the start button. As soon as the car starts, the left turn signal turns on. First time it happened, I thought maybe I hit the stalk or something, but then it happened 2 more times since. Always in the morning. I'm not too concerned at this point, and kinda though it was amusing, but hoping it gets it poop in a group and goes back to normal soon.
Probably a fault in the switch that is sensitive to temperature (contraction and/or expansion around the switch). I suspect replacing the switch would fix it. It would be covered under warranty, but getting it to act up for the technician will be difficult. Maybe try taking a video of the problem so you can show that as proof.
The actual turn signal turned on, as in it clicked inside? I can't even begin to think what would cause that other than a wiring defect, but I'm not sure why cold temperatures would affect that. I would have expected that sort of thing to become prevalent in hot temperatures (when insulation can weaken or melt), not cold.
The turn signal stalk was in the center position, but the left blinker started happily flashing away as soon as I hit the start button. Like I said, it was weird. I have 40k miles on the car and have had it since new 17 months ago. This is the first time it has happened. I've had a few random ghostly software things in that time, but nothing that effect actually driving the car. Its just been things like this turn signal thing, 2-3 times I've had random chimes while driving with no indication of why, and some goofy crap with connecting my phone via Carplay where I can't get any audio except for AM/FM radio. In the case of the radio, it gets stuck in some connection loop where the phone connects, disconnects, and reboots the infotainment system until I pull over manually disconnect it and restart the car. Its annoying as hell, but doesn't happen often enough for me to consider a trip to the dealer.
1 - 5 of 5 Posts
