WOW I think that's my 2018 in the picture. Have not yet had the dreaded BECM issue but looks like there may be hope if I do. Fingers and toes crossed.
WOW I think that's my 2018 in the picture. Have not yet had the dreaded BECM issue but looks like there may be hope if I do. Fingers and toes crossed.View attachment 175614
Neither here nor there, but I've always been happy I kept my Gen 1 and did not trade up to Gen 2...
BECM change to the last revision?Has Chevy made any changes when they repair the car to ensure it doesn't reoccur???
reimbursment for repairs/replacements and issue recall it would seem.It's not clear what exactly they want from GM... Issue the recall on BECM?
General Motors has allegedly known about the Chevy Volt battery energy control module problems but has failed to warn consumers of the issues. The automaker has also allegedly refused to offer reimbursements for repairs or replacements, and the lawsuit alleges GM has never issued a recall.
The plaintiff claims once the module has problems, the only fix is to replace and reprogram the Volt battery energy control module.
Have you seen how many have had the drive motor bearing issue? Battery section replacements? I wouldn't say the Gen1 was more reliable.No car is perfect.
It does appears then gen1 was more reliable
Not many, and the battery is simply age related, Gen 2's will eventually experience the same thing unfortunatelyHave you seen how many have had the drive motor bearing issue? Battery section replacements? I wouldn't say the Gen1 was more reliable.
I read the filing. They want GM to fix the underlying problem and replace all the BECMs as well as reimburse owners for their rental expenses while their Volts were out of service.It's not clear what exactly they want from GM... Issue the recall on BECM?
Court cases can take many years, and then appeals.The waiting is exhausting.
Based on your post you won't be part of the class since GM replaced your BECM and paid for your rental. Likewise I won't be in the class as GM replaced mine under warranty and I had no out of pocket costs.I had my 2018 failed BECM replaced recently at around 36,000 miles. It took about 3 months to get the part. GM provided a rental car during that time and covered the repair cost per their warranty. I verified that the replacement BECM was indeed the new part number 24296900 per their latest Technical Service Bulletin on this issue.
I, and most Volt owners I expect, would prefer that they issue a recall and/or expand the warranty coverage for this well known problem. That said, given the current 3-4 month delivery lead time, it may be that the only way GM could accomplish a blanket recall in the near term is if they are choosing to produce replacement BECMs at a trickle pace. I suspect that is not the case, if for no other reason, because the cost for 3+ months of rental car fees far exceeds the cost of a BECM warranty repair. What GM has been doing for over a year now is simply more expensive (to GM) than ramping up production to have a high demand warrantied part readily available.
I think a voluntary recall or warranty extension is reasonable in this case, and the lawsuit may eventually accomplish that. But for the time being it appears that GM is still working to manage an ongoing messy situation. How much of it is due to lingering COVID supply chain issues and/or parts inventory mismanagement is a matter of opinion, and beside the point. I do hope that GM does more to resolve this issue, but I don't see myself joining the class action.
