1 - 10 of 10 Posts
Bumping this. How hard would it be to put one of these into a battery electric vehicle already on the market? I suspect that the serial hybrid vehicle can be feasible and cost-effective without waiting for GM to roll out the niche-market volt. What engineering challenges are in the way?
That's funny. I think that the original post was spam, but we're talking about it now. :p Anyway, these generators were built to power a (mostly) resistive load. If you try to just rectify the output and hook it up to a battery, then it will be unstable as it goes above and below the point at which the rectifiers conduct.
whoops I didn't check out that link before posting
So how much of a challenge was/is it for GM to put a range extending gas engine in the volt? From what I understand the engine only has to run at a constant rpm to recharge the batteries.
RATS! I sure wish someone had told me 20 years ago that I could not charge batteries with a portable generator:eek:... That means that for the last 20 years my tractor battery must have just abosorbed radient energy from a tesla wireless power transmitter in Colorado Springs or something. :D
You see, I regularly start up my Honda generator, plug in my NAPA battery charger, and charge the old battery in my tractor when it goes dead. I could have saved some gasoline running that generator had I know it wouldn;t work.:rolleyes:
Yes, this works because you have the all important "NAPA battery charger". This is a current source.
I don't believe anyone would foolish enough to attempt to connect a standard generator directly to batteries, even with rectification and filtering.
At least, I hope no one is that foolish. . .
I just want to know what it takes fit a gas generator into a battery electric car. It seems like GM has put a lot of energy into the software that controls the range extender, I guess mostly to maximize battery life. But what's stopping other companies from doing the same thing?
edit: http://www.gm-volt.com/forum/showthread.php?t=1126 well what do we have here! Now all we need is for someone to make this happen in a small car that doesn't cost 80 grand :(
All you have to do is rectify it, filter it and connect it to the regen braking shunt. Works like a charm.
1 - 10 of 10 Posts
