1 - 8 of 8 Posts
Does anyone get oil puddled under generator? I'm at dealer now.
Oil puddles under the gas engine? Only if there is a leaky hose, oil change overflow, or some other issue.
It's a typical gasoline engine like any other. Oil should stay on the inside.
I believe oil pan seal leaks were pretty common on some model year Volts.
Oil doesn't belong in a puddle.
The range extender engine is still a fairly normal 1.5L DOHC GM engine very close to a Chevy Cruze (May it also rest in peace) engine or perhaps a non-turbocharged version of a Malibu engine, just one with a specialized RPM control and a specialized transmission for voltec design.
My 2014 just had the oil pan resealed during it's 2nd oil change....no charge for either :D
1 - 8 of 8 Posts
