So as some of you remember I ran my tank down to "LOW" and felt the "total range" number should have at least reported EV range in this situation - that's a discussion for another thread (an yes, I firmly believe this is a Human Interface Design 101 error to report LOW for total range when the battery is full). This thread is about what actually happens when a Gen 2 Volt runs out of gas.
Range "LOW" occurs with 0.9 gallons of gas left in the tank.
When the car actually runs out of gas it alerts you with a rather loud gong (70's Gong Show anyone) and the DIC flashes Engine Not Available Fuel Needed and then switches to Propulsion Reduced. At the same time my Volt went from Hold Mode to Normal Mode for driving.
Both these alerts are clearable. The Total Range still shows "LOW" even though I had 60 miles EV range showing under the Battery SOC meter.
Power reduced is just that - a maximum of 52 KW instantaneous power was available and the throttle responds like there's a floor carpet/mat wadded up under it. In addition, on the Mode display only Normal was available. Sport, Mountain, and Hold mode were unavailable. Mountain and Hold make sense as they both require the ICE engine. Sport Mode, which I never use, was disabled, I'm assuming, because the car had gone into a hypermiling mode of reduced acceleration. What I did notice was that acceleration during cruise control resumes were not affected.
At the gas station, first click off was at 8.8 gallons and I ended up with 9.6 gallons in the tank after I pumped to the next even dollar amount. Fuel was not visible even at 9.6 gallons based on how the gas pump was responding I suspect there was at least another half gallon of fuel pipe available - total fuel capacity is closer to 10 gallons than the tank rated 8.9 gallons. When I started the car everything came up normal - no indication the car had done any sort of fuel or ICE engine testing to ensure there was gas in the tank. Nor did I hear any main fuel pump refilling the fuel lines from the tank to the injectors.
And yes, this was the first time in my life I've ever run a car out of gas.
