Question for all of you that may want an inverter kit for the Gen 2 Volt, similar to what is available on the 2011-2015 models.
Would you prefer the plug be accessible without opening the floor up?
Instead, if below the floor, there's a nice spot in the center where the connector could reside, for example, just in front of the battery. See the image on this post: http://gm-volt.com/forum/showthread.php?279841-Trunk-Junk&p=3922793#post3922793
The floor lifts up to reveal this section quite easily, which is why I pose the question.
The other option is to have the connector accessible from the left compartment of the hatch, which more closely resembles the inverter kit for the Gen 1 Volt. However, this requires a bit more cabling and routing, and getting the cable through to that location is a bit tighter and probably a bit more annoying for people to install.
Thanks in advance for the feedback!
