My early impression--subject to revision--is that my Gen 2 does a worse job "holding" EV miles than my Gen 1 using it on the same commute.
I can't figure out if Gen 2 tries to "get back" to the held SOC setpoint, especially if it requires battery power beyond the ICE alone. On my Gen 1, the ICE (mostly) added charge to maintain the HOLD setpoint--but it also operated in a serial hybrid capacity. On my Gen 2, it seems that whenever it needs battery + ICE (like hard acceleration), it doesn't try to "replace" it. Maybe a characteristic of the parallel hybrid setup? Or maybe it tolerates more deviation?
It seems this member also noticed this issue on a 2000-mile trip where he used "hold" the whole time and lost half his EV miles. http://gm-volt.com/forum/showthread.php?284690-Questions-about-Hold-mode
What's going on here? Is the battery just augmenting the ICE in Hold mode? Do I need to drive within the (lower) power demands of the ICE alone in hold to avoid drain? Under what conditions (if any) will Gen 2 maintain the Hold setpoint?
