This morning was about 6 degrees F, I set my climate control to share floor/defrost and headed out.
Very soon I noted the windshield was starting to fog except for right above the vents. Floor heat was fine.
I hit the full defog button and there was an audible thump as the ducts re-directed all air to the windshield which quickly cleared. When I set it back to share floor/defrost it went right back to just the floor and barely any windshield.
I clearly remember last winter that the sharing between defog/floor was pretty even and worked well. Also the system used to switch between settings with a sort of "whoooosh" sound, now there is a fairly abrupt muffled thump as it moves from floor to vents to defrost.
Any suggestions for what I might inspect to see if there is something I can do about this?
UPDATE: ISSUE RESOLVED. SEE POSTS #5 AND #6
