1 - 3 of 3 Posts
A little DIY to repair a door handle button that quit working.
Tools required
  • A small flathead screwdriver
  • 7mm socket
  • 15 Torx driver
  • A dremel with cutting blades
  • Wire cutters
  • A soldering iron
  • hot glue or epoxy
First remove the door card, door handle and connector. See video below:
https://www.youtube.com/watch?v=br-eyjOWYjw
Good luck with the connector, broke mine
With handle in hand, remove a portion of plastic underneath the button:
Remove the silicon from the top of the switch (flat head screwdriver works, be careful not to damage wiring:
You will see a wire that was detached due to corrosion. Pull a bit of insulator from the wire using cutters:
Solder the wire:
Fill with hot glue or epoxy. I like to shape the glue while it's setting with a piece of parchemin paper.
Reassemble and enjoy.
It looks like the images you posted are dead. Would you be able to re-upload them?
The missing images are the result of this forum changing over to the Xenforo software. Complain loudly to Admin.
1 - 3 of 3 Posts
