1 - 5 of 5 Posts
Hi guys, I collected my car on Saturday, a 2014, the charger was working initially, and yet this morning refuses to work in the socket which was previously fine. Tried at another house as well as various sockets with no luck. Car says ‘unable to charge’ and I have one solid green and a flashing red fault light immediately that the charger is out into the wall socket. Does anyone know why this might be ?
Many thanks
I had this and it was because none of the outlets in my garage were properly grounded. When I plugged it into my house it worked. Sounds like you tried plugging into multiple outlets already though. Good luck. I hope you get it figured out.
let us know if you want us to post a picture of which light is which.
I find it is good to know which is the Smoke and which is the CO on my fire alarm :)
Lights depending on type can be low voltage/bad plug or ground loop
1 - 5 of 5 Posts
