I've had my 2013 for over 4 years, but since we've just switched to TOU, it's the first time I've programmed the charge time. It seems to be working, but there is something I'm not sure is right. I RTFM and searched some threads, but I don't see this particular issue.
It holds off charging and seems to start and end when it's supposed to, but in the morning, despite having a full charge, the green light on the dash is completely off, there is a warning on the dash that says something about charging being interrupted, and the EVSE's red LED is on. The first time (yesterday), I thought I had blown a breaker, and reset everything, and it started charging again. However, this morning everything was the same as yesterday, so I left it all alone and just drove off. Center console said full charge and all miles had been reset like normal.
Is it normal to have the green dash light off and the red EVSE light and the interruption warning at the end of a full programmable charge cycle? TFM suggests the dash light should be flashing green for a full charge, even when it's at the end of a programmed cycle.
Appreciate all thoughts, including something stupid I'm missing and nothing's wrong after all. Thanks!
