Last week my cabin heater (HVAC) on my 2016 Volt suddenly stopped producing any heat. Also no defrost. Cold air only coming out. Not fun in the freezing temps here in the Northeast. After two days, I called my dealer. No appointment for three days. This morning I was making a 50+mile commute into New York City. After my routine 15 mile EV drive, I perform my typical transition to ICE mode for the high speed highway portion (about 15 miles). Five miles into the ICE portion I get a warning "Engine Overheat - Reduce Speed Immediately". I was driving about 65 MPH and outside temp was 38 degrees F. I slowed down and pull over. Engine coolant temp was 258 degrees!! I tried putting on the HVAC heat to siphon some engine heat and it did nothing - more cool air from the vents and no decrease in engine temp. I switched to EV. Coolant temp fell to about 75F. After 10 miles I returned to ICE mode. Coolant temp shot up in 30 seconds to 230+F.
After toggling between EV and ICE mode I hobbled into work. Opened the hood and inspected things. The radiator reservoir was basically empty. Then I inspected the hoses and area. There was obvious evidence of a coolant leak. Then I saw this (see attached photo). A puncture in my coolant line on the underside near this triangular cast metal piece on the engine. I ran my finger over the metal piece - it is insanely sharp and is the obvious cause of the radiator line puncture. What on earth is this metal piece for and WHY is it SO SHARP!!!
Has anyone else had this problem yet? This seems to be a disaster for many owners waiting to happen and an obvious Recall item. Then when I went to restart the car I got a failure of basically every single car system. Airbags, front and rear cameras, side view warning system, etc., etc. WTF!!! After driving for another 20 minutes, I stopped and restarted the car and the warnings went away.
I love my Volt, but this is freaking me out.
