This has been "one of those days" on top of "one of those weeks". No sun all week - peak output from an 8kw array has been on the order of 150w for a few minutes at a time. Small Honda generator 3 qts a day of gas. I shouldn't have this computer on, and will turn it right back off when I'm done posting.
I overslept this morning (nice electric blanket) and didn't get out to start the backup generator till about noon, when my 24v nominal system was down to 23.1v - ugh, that's hard on those batteries, and I was about to have my first actual power failure in over 34 years of off-grid living. I prefer infinite 9's uptime, so time to act.
Well guess what - the Honda died about 10 min after starting it, and here I am, with snow/sleet coming down at about a 4"/hour rate, and no power. Honda has no spark, and it's wet all over, so I bring it in, but can't find the problem immediately (it's really packed tight in that little box). And yes, when my other, less efficient backup generator died, I should have either fixed it (spun output shaft seal) or bought another. One spare is never enough, I know that, but I slacked - all my bad.
Sooo - I finally get a real test of the Volt inverter hack. I have a forklift ferroresonant transformer battery charger I use with the Honda, or whatever. This time, I used the Volt inverter hack I'd installed in the car for just this sort of thing. And, it works! It's been running since about 4:30pm (it's now 6:30 pm), but due to the Volt's unique system, it actually only runs 1:25 (one minute, 25 sec) about every 10 minutes. I'll brave the ice and go see how much gas it's used, since it's about time to turn it off anyway - I have gone into extreme power conservation mode for the night, no blanket, turned off my vacuum system on the fusor, only nightlights and book reading for now.
But the point is, no matter what the gas number turns out to be - it just saved my a$$. And my 100% over 34 years uptime. I am NOT whining.
I am pumping out around 25 amps at now 25.8 volts, from a 1.3 kw inverter/battery charger into the house system, and I won't need to fully charge it to survive the night - tomorrow is another day after all. I could use a more efficient charger, this one draws about 700w to put out about 650, but...life.
The setup is like this - Volt is in mountain mode, on, keys in the cup-holder, in the driveway. 50 ft extension cord to the "energy shed" and battery charger. I will have used some extra gas because the Volt wasn't charged up to the MM threshold when I first started it - that took an extra 10 min or so of running hard. Further, for the first hour, I had the heat on, the defroster etc - the snow load on the hatch was such that it was very hard to lift it to get to my inverter output.
But now it's happily cycling with a pretty low duty cycle - one wonders if in this cold weather it's not as efficient as it could be - with the engine cooling for 10 min between runs, and only running about a minute and a half each 10 min, but hey - when the going gets tough, you have to make some compromises. So my mileage numbers this year won't be so stunning. Oh well.
OK, in two hours running, I've used just 0.5 gal of gas - not great, but not terrible - I could leave it on overnight if I wanted to keep everything in the house running as normal, but I won't - this is an exceptional case, so I'll just get enough charge to survive till tomorrow (with even my modem/router turned off - everything I can find, even the battery charger for my hand tools), when maybe the honda will run again after drying out, or...we have sun predicted. I expect the extra gas was from running the heaters and defrosters for a bit till I realized that even they could not keep up with a snowfall (mixed with ice/sleet, wonderful) that is now bordering on 8" - in just a couple hours. It's going to be rough to lift that hatch again to turn the inverter off so I don't run the 12v down overnight, but I shall live - and well - and the Volt just saved me from a rather nasty emergency.
Even my 4WD truck wouldn't want to be going out tonight to try and find a generator replacement. With 8" or so of sleet/ice/snow the Volt wouldn't even make it to the road, much less anywhere else - forget the air dam, the snow is near the middle of the wheels in height!
Now I'll turn off the world, other than my one reading lamp (10w LED), night-lights (10 more watts of leds), and dorm fridge, and hope we still have power in the morning. I bet this does it. I'll report later, of course.
Looks like being a decent engineer has paid off - again.
