I know my Gen2 tire placard shows 36 psi as the correct tire pressure, but I wonder if any of you here have adjusted your TP to achieve certain goals. For most owners here, you probably think of MPG or eMPG. Other goals might be even tread wear or smooth ride.
If you were only concerned about MPG then you could jack up the pressure to the max on the sidewall (44) and be sure you're getting the lowest rolling resistance. But the ride would be rougher and the tires would wear in the center of the tread.
My "other" car is a 1999 Monte Carlo. It's placard shows 30 psi on all 4. That never made sense to me because it is very heavy in the front and the front tires at 30 look half flat. I've owned the car 18 years and I've been running 36 in the front and 31 in the back. I get even tread wear and I believe I've figured out what that car is happy at.
I am too lazy to look up the weight distro on my Volt but I'll bet it's a lot closer to 50/50 front/rear than my Monte is.
You guys have any ideas about this?
