Greetings folks, few basic questions that I can not find a solid answer for. This may just be my google-fu failing me, but I am hoping you folks can point me in the right direction.
This is pertaining to a Gen 1 - 2012 Volt that appears to not have the Navigation/Backup Camera options, but it has the Bose audio system, so it may have the 30GB HDD? Not sure how to verify this. The previous owner attempted to delete some of their mp3/recorded music but it now resides in a "recycled" folder that I seem to not be able to empty. The music is still playable and is pulled into the Shuffled option with my USB stick. Long-press of the Recycled folder doesn't give me any additional options to permanently delete. Any additional means to purge the data from the system?
Bluetooth connections. Once I pair to my phone (Nexus 6P unmodified) the connection stays for mere seconds. I can see the signal bars and the BT icon lights up, then poof, gone. Same issue for a Note 2 (rooted) and an Iphone 4gs. Dealership mentioned that all usual software updates were done. Searching seems to only pull TSBs relating to battery drains from Bluetooth calls. I've tried the troubleshooting steps from other threads, deleting the paired connection on the car/phone and restarting the car/phone and the like. No good results so far. Bringing this up to the dealership since they also can't seem to get the "free" 3 month OnStar to work either.
High Beam shutter 'volume'. I only noticed this while sitting in the car in front of an office building (mirrored) and looking at the car's light output/DRLs etc, that flicking on the High Beams causes a bit of a loud noise when the projector beam shutter changes position. Normal?
Otherwise this car has been great. Just the concept of trying to 'hypermile' my 50mi commute to stay above 100mpg on a full charge is mind boggling. Appreciate any advice on the issues above, or any direction to pertinent threads relating to those issues.
Thanks!
Thanks!
