I got in a discussion with someone in the Bolt EV Owners Group on Facebook, and he and I seem to disagree about proper etiquette when using the public fast charging infrastructure. Essentially, the disagreement is this:
His opinion: EV drivers should limit themselves to only 30 minutes of fast charging if another EV owner arrives at the charger and would like to charge.
My opinion: EV drivers should be able to use the charger for as long as they need to gain the range necessary to drive to their next destination. Essentially, first come, first served, and you use it as long as you need.
Personally, I think his perspective is based in a longtime ownership of short-range BEVs that nearly charge to full in a single 30 minute session. But the paradigm has shifted. Bigger battery cars are available, and it doesn't matter that you need 20 minutes of charging to get to your destination 40 miles from here. If someone else was there first and needs an hour of charging to get to their destination 160 miles from here, you should have to wait your turn. Maybe my opinion is off base, but I'd like to hear what the community here thinks.
