1 - 5 of 5 Posts
Does anyone know what the factory rear toe setting is? I have 1/16 inch toe in. There is no adjustment on the rear end, but I am wondering if I somehow bent something, or if this is correct.
Also what about toe for the front? Currently I have set it to 0.
The spec for front toe (L+R) is: 0.2°± 0.2° rear: 0.15°± 0.4°
WOT
Why you should align your car
This *may* help answer. But then, it is just plain scary how smooth the Volt is while being that far out if spec.
Discussion Starter · #5 ·
Thanks SirSpammenot, that shop is just a few streets down from my work. Looks like you had a little bit of toe out. It is interesting that you had -.12 degrees total toe before, and .24 degrees toe after.
I am visioning the front wheels pulling on the A arm bushing and increasing the distance from the tie rods at highway speeds and thus creating ~0 degrees toe...
At any rate, you answered my question. The front and rear should have about equal toe in. Thanks!
1 - 5 of 5 Posts
