1 - 7 of 7 Posts
Has anyone extended the cable for a level 2 charger? I am looking to mount "charger" in garage and hard wire to an outside junction box where the original cable will be connected. Of course I will upsize the gauge of the current carrying wires. I will probably shorten the original cable some as the junction box will be close to car.
The J1772 cord should only have 4 wires, larger gauge wires for 2 hot and 1 ground, then a smaller gauge wire for pilot wire. The proximity signal returns through the ground wire. As for an extension, I don't see any reason you couldn't, although they also make J1772 extension cords if thats another option you might consider.
Article 625 of the National Electrical Code limits the maximum length of cable between EVSE and vehicle. I believe the limit is 35' but you could look it up to be sure. In case of a mishap that could be attributed to your installation you should adhere to the code and, depending on municipal regulations, have it installed or inspected by a licensed electrician.
KNS
If you're looking to extend the Hot, "feed" side of the EVSE, yes certainly, just provide sufficient gauge cable for the current and length. Many L2s are only fed with 3 wires, L1, L2, GND. The EVSE to J1772 side can also can be extended, I added a section of common SOOW 12/4 cable on the J1772 side, available at home stores. It carries the same L1, L2, Gnd, and Pilot as the original EVSE cable.
Technically, the charger is in the car, under the passenger side bumper area. I would not extend the J1772 side, but extend the electrical feed. If I could have a do-over, I would shop for a 25 foot EVSE cord instead of the 18 foot one I have today. My EVSE has a pigtail to a 30A plug where I should have gone with a 40A one. Finally, I should have paid extra for 2 electrical runs instead of one so I could move the EVSE to charge the car inside as well as outside. I tend to charge outside in the summer to avoid having the volt's AC kick in spewing heat into the garage when it's hot outside. Today I use my L1 charger outside, and wish I could use the L2.
GM's warning, no extension cords, period.
1 - 7 of 7 Posts
