1/8" drill bit fits through the lock hole in the release button, also 9/64" drill bit will clear. 3/16" is too large.Is the hole for the lock 1/4", 1/8", or 3/16"?
Thanks!
There is a hole in the release trigger lever of the stock Gen II Volt EVSE vehicle connector where you can insert a small padlock making it impossible to disconnect the EVSE from the vehicle without first removing the lock without breaking something.OK, I can't let this one go... WHAT???
Thank you. As a Gen1 owner, I didn't know this about the Gen2. Do many use this feature?There is a hole in the release button of the stock Gen II Volt EVSE vehicle connector where you can insert a small padlock making it impossible to disconnect the EVSE from the vehicle without first removing the lock without breaking something.
I don't worry about locking the EVSE connector when charging because I charge at home, in my garage.Thank you. As a Gen1 owner, I didn't know this about the Gen2. Do many use this feature?
Agree with those findings. I measured the hole diameter at .140 " (3.5 mm).1/8" drill bit fits through the lock hole in the release button, also 9/64" drill bit will clear. 3/16" is too large.
EVSE hole measured .140.While the design of this connector may be an industry standard, the size of the hole for the lock apparently is not. You'll have to measure your own connector to know for sure. My 40-amp eMotorWerks JuiceBox with optional "soft" cord has a lock hole that is a tight fit with an 11/64" (.172") drill bit. Anything smaller will fit. I don't know what size the hole is in the car's supplied connector. I've only had that EVSE out of its storage bag once, to make sure that it works. It hasn't seen daylight in over a year.
