EV Range limit is only 86 miles?
9716 Views 51 Replies 27 Participants Last post by  Runion
I've had back to back 90-199 miles per full charge and yet my EV Range from the GOM never exceeds 86 miles after full charging that follows. Has anyone here started out with an EV Range of more than 86 miles?
Volt86 by Joe Real, on Flickr
21 - 40 of 52 Posts
I have explained this one in some other threads on how to achieve what seems to be impossible. I demand apology from the insults hurled at me.
I have explained in part how I achieved 499.61 miles in a single day and made it to number 1 in VoltStats, but none of you cared anyway.
http://gm-volt.com/forum/showthread.php?310218-499.61-Electric-Miles-in-a-single-day!
Sure, but that's why I asked what I asked. I knew people would want to know what is behind the number. Ignore that basic curiosity and your post will be viewed with some skepticism. And it was.
Thanks for clearing that up.
Hypermiling, recharging many times during the day, driving downhill can all help to achieve EV miles that exceed the battery range. And that seems to be what you did.
In answer to your question, no the highest I have seen on my car is 50 miles, it's also a gen 1, and I was simply looking for how far I could go on a single charge, flat ground, no multiple recharges.
Thanks, and I was just confirming for my 2017 Volt that the upper limit in the instrument panel display would seem to be 86 miles even if you regularly drive more than that via hypermiling, elevation changes, mountain mode combos.
Right, you have proven the display wont show higher numbers based on an "artificial" range built on multiple recharges, etc.
The start of day, full charge ev range estimate is created by multiplying a computer calculated estimate of the vehicle’s average ev mileage (based on historical driving data collected by the computer, weighted for more recent data) by the amount of usable available power.
Keep in mind that no matter how far your drove the previous day, the full charge ev range estimate for the Gen 2 will be determined by multiplying a usable power amount of ~14.1 kWh by an ev mileage number. The question is, how does the computer algorithm calculate that mileage number? Is there a fixed limit to the displayed range estimate (as 50 miles was for the 2011/2012 Volts and 60 miles for the 2013/2015 Volts), or is your displayed 86 mile estimated range accurately reflecting recent achieved "ev mileage?"
The kWh Used number shown on the energy usage display screen is a net calculation (grid power used less regen put back into the battery). Nissan Leaf owners once had a "Carwings" app (perhaps they still do), detailing the power consumed for each trip as a sum of the battery kWh Used (positive) and the regeneration obtained during the trip (negative). It could be the Volt computer maintains the same grid power/regen power consumption data, and uses total trip power consumption data, not just grid power data, when creating the "average ev mileage" number used to calculate the full charge range estimate. How much regen power was included in the total power you used to drive those 90+ ev mile trips?
Your route apparently included a lot of downhill driving. Driving a route that allows you to add a significant amount of downhill regen to your "Electric Mode" fuel supply might allow you to drive more Electric Miles, but if the "level terrain ev mileage" you get from use of grid power is about the same as the "level terrain ev mileage" you get from use of regen created power, the start of day, full charge 86 mile ev range estimate might well be a calculated number, not a maximum number. The full charge range estimate isn't going to estimate how much regen and regen miles you might get that day.
Your ~500 ev miles in a day post mentioned that you added some Electric Miles at the end of the drive by using Mountain Mode to recharge. It could also be that any "Electric" miles driven on MM recharged battery power are excluded from the start of day algorithm’s average ev mileage calculations. My 2012 Volt has the quirk that allows MM power to be counted as Electric Miles, but the kWh Used number on the display does not change as the power is used. This quirk once produced a display screen showing I had driven 89 Electric Miles on 9.8 kWh Used. The following day’s full charge ev range estimate did not receive a "bump" from this "I averaged 9+ miles/kWh over ~90 miles" achievement. By not increasing the kWh Used number when MM-recharged power is used, the computer is identifying it as "not grid power," so perhaps the computer also does not include any "Electric" miles driven using the MM-recharged power when calculating the average ev mileage to apply to the full charge ev range estimate calculation.
Perhaps these observations will add to the discussion of how the ev range might be calculated.
I note that neither of the two charts you posted indicate a full charge electric range for a 2017 Volt of more than 70+ miles, suggesting the 90+ mile numbers you are getting are much rarer. Our friend Ari C drove 114.0 electric miles on 14.4 kWh of power using his wife’s Gen 2 Volt (no gas used, no gas miles), so it is indeed possible to reach those distances on a full battery charge. If I recall correctly, his next day full charge estimate was 84 miles.
Your description of the route you used for your ~500 mile in a day drive seemed limited to level terrain, downhill, level terrain, downhill, ending with a little Mountain Mode recharging. The finer details of the achievement, such as average speed and how the other drivers on those roads were reacting to such slow driving (and where those roads are, for others who might like to attempt to reproduce your results), were not given. The implication is also that your long electric drives are achieved because they include several downhill sections (for regen), and are not round trip events. Ari’s 114.0 mile drive was mostly driving in a big oval on relatively level terrain. It doesn’t seem unreasonable to expect someone who posts pictures of a usage screen showing 186.8 and 199.7 electric miles driven using only 14.2 and 14.1 kWh with no gas used to elaborate on how this was achieved.
I do not understand. Even your graphs show that it is impossible. I’m thoroughly confused unless you were driving 20 mph downhill for 25-30 miles.
If you have followed my other posts about these graphs it was explained in their proper context. My point was I've been collecting data, very observant with my Volt and I am insulted if someone calls out my observations as BS when I provided proof against their disbelief.
These graphs were for normal driving, such as level roads, more or less maintain constant speed, and then analyzed statistically for the patterns when using your Volt normally.
I was pushing limits of the Volt, beyond the confines of these graphs. In fact Ari Collins was able to do 122 miles on a charge driving less than 25 mph along an elliptical stadium for hours. I pushed it further on my first try by finding elevated charging stations and slide down from there and I have achieved 186 miles to a charge.
I then took up the challenge of beating the record in VoltStats for number of electrical miles driven in a day, and I have studied those graphs to aid me in the optimal speeds to use. I then have a fully charged Volt starting out at the highest elevation that I can find, and then driving level road at optimal speed to deplete the battery then slide downhill until battery is near fully charged and then drive level road again to deplete it and continue the process. I achieved nearly 200 miles to a charge. This is a record achievement run, not your normal use of the Volt, the same reason why Tesla drivers would crawl drive to establish the longest distance records with Tesla, or why would someone climb the peaks of the mountains...
So I used various hypermiling techniques. I've even calculated the expected recharge rates for regen from downhill elevation changes. Did some tricks with mountain mode and normal mode... In many of these instances between recharges, I achieved at least 90 miles to a full charge, going as high as 199 miles. That's when I noticed why the GOM for the EV Range seemed to max out at 86 miles. Normally, the EV Range in the GOM reflects your performance the previous charging cycles, and all my previous charging cycles were over 90 miles to a charge and yet, the display for the start of the next run never exceeded 86 miles for me, and that is why this post. So I'd be the first one to actually confirm this limit on the display if no one else can show me.
My record of 199 miles for a single charge has no external charging, as I have used 14.1 kWH shown in the DIC. But it was from the highest elevation that I can find, drove like a grandma in the windflow level road, then when battery was depleted, drove downhill at optimal speed for regen, and when the battery nears full from the regen drive level road again and repeat the process. The overall conversion efficiency of potential energy from elevation change to regen is approximately 75% and by driving carefully I didn't lose anything to friction braking. My record can be beaten if a higher elevation can be found to start driving.
I've never seen more than 65mi estimated on the gen 2 with a full charge. BTW OP, fix those tire pressures asap. They're all over the place.
Can you confirm Joe that your daily record used no gas that day?
For me, a Frustrating Voltstat that never happened;
The day I planned to see how many EV miles I could do in one day Starting and Ending at my house, 258 miles, was one of the days Voltstats decided to NOT collect data that night. lol
This was just driving like grandpa but speeding up when needed as not to affect traffic with intermittent recharges at home. I think I could probably hit 280 miles if I ever feel the need to try again.
Not that it matters but to only a few, I too have a worthless stat on Voltstats that will be very difficult for anyone to beat.
#1 Overall, hence "The BEST of the Lousiest"
https://www.voltstats.net/Stats/Details/3384
Although I did leave a slivers chance for somebody to take my Spot
The 75% recapture from regen seems to agree with GM statements in the past.
Going 199 miles on a single charge can be misleading without knowing it's really 199 miles with lots of coasting/regen down a mountain road. A bit like loading the fully charged car into a rocket, shooting it around the moon, bringing it back to earth, and claiming the car traveled thousands of miles on a single battery charge. It did technically, and it didn't in the way most people would travel on a charge.
In both cases, the energy it took to get to those heights and make the claims is not accounted for. The regen/recapture traveling downhill is recovering what? The energy it took to go UP the mountain. No free lunch.
Same with orbiting the moon. It took a lot of energy to boost the car into orbit. So both claims, to be accurate, should account for the energy used to go uphill in order to go downhill. I suspect a net energy loss in both scenarios. The 75% regen recapture suggests that at least 25% of the energy it took to go up the hill was lost going down.
If gas was used to go up the hill, it's even worse. Gas engines are only 25% efficient at best, wasting 75% as heat and noise. But maybe I am all wrong. How did you get up the hill to do your downhill, record setting "199 miles on a single charge"?
...How did you get up the hill to do your downhill, record setting "199 miles on a single charge"?
Charge at the bottom, charge again at the top. It wouldn't be too hard to do up in the Sierras going up I-80, around Lake Tahoe, and down U.S. 50 - then along the foothills. Lots of L2 available along the route. Pretty nice scenery too. Much better than driving around a football stadium.
Joe has proven conclusively that there is positive energy to be gained in dropping 3500 lbs downhill from high elevations.
That's all.
And it appears the the GOM has an upper limit to avoid people playing games with that imaginary number.
I think what Joe did was to show the extent to which some folks will go to demonstrate a point -it is possible to get 86 miles or so under the conditions that most Volt drivers will not encounter. I recall when the Nissan LEAF arrived in 2011 that there were several demonstrations of its range. One LEAF driver went to some major effort to drive from the Mexican-to-Canadian border with limited charging infrastructure, but he managed over a period of days. Someone else showed that the range of the LEAF was close to 140 miles, but at a speed of about 38 mph, IIRC. So, this range required a drive of over 3 hrs. We also hear of Tesla drivers going across country in a few days. Then there is ElectricTerry who won the IronButt contest by riding his electric motorcycle a 1000 miles or so in 24 hrs [RT from the SF Bay Area to the Mexican border]. We need these types of folks to push the limits of driving EVs and make driving EVs more interesting for the rest of us.
I was able to obtain 82 miles on a full charge one time. I was at the top of a mountain in the Catskills in NY.
I can totally believe Joe's figures
Sure, my point is you have to include all the charges (gas and or electric) that got you to the top. If it took two charges to get 199 miles on "one" charge, well, it's not really one charge is it? Again the regen going down is recovering energy it took to get you UP to the top. No free lunch, no perpetual motion machine.
That is so true. Remember that these are no ordinary attempt so no ordinary use of Volt. One can go crazy in quest for records, no crazier than some Tesla fangoils or fanbois attempting longest record run by going slower than grandma. No crazier than people risking their lives and dying to scale Mt. Everest. All for craziness, all for fun. The challenge is to get the record, hill or mountain or stadium. Push the limits!
I think one of our members here also attempted a record day run using Gen 1 Volt. The Volt was put on a flatbed trailer and has a generator and it was carried to the mountains, and while going there, being recharged with a portable generator. Repeat the process a few times as to how much money you can burn for the flatbed trailer gas going up and down the mountain. I think the member got more than 350 miles and first broke the record for such a electric miles in a day feat and would have gotten over 500 miles but stopped and called it a day after just a few trips.
Yeah, just like the OP, I attempted a downhill run from Yosemite down to Bakersfield via the backroads drafting behind the slowest farm cargo trucks that I can latch on and mountain mode recharging trick. I got 450 miles but was never recorded because at that time VoltStats cannot read my data from OnStar... waaah :( :( :(
My readings on my GOM went only as high as 84 the next day after a full charge.
I have only had my 2012 Volt since November and have only ever seen 33 miles estimated range and only 40 degrees F except for today which was 60F but my charger (outlet apparently) failed last night and I only had 9 miles EV range this morning.
My commute has required the gas engine to kick in every single day since the day I got it.
I had my charge cable fail 1 week after getting my car and I spent a week on engine only until I got a new cable.
I spent over two weeks at frigid temperatures that required ERDTT most of my drive every day. And one day it gave me dismal 19.1 mpg.
But my lifetime mileage is still better than the OP. Lots of (inefficient) effort going into getting some big numbers on the display.
The OP prefers to configure his display screen for "MPGe" numbers, which aren’t available on the 2012 Volt’s display screens (I’ve been driving my 2012 Volt for 5.5+ years now). His MPG and MPGcs lifetime numbers are much higher (1000+ for MPG, ~47 MPGcs).
One "gallon," in miles-per-gallon-equivalent terms, is equivalent to the energy available in 33.7 kWh of electricity taken from the wall. The battery of the Gen 2 Volt holds about a "half-gallon" of MPGe fuel per full charge. Averaging 114 MPGe in a car rated at 106 MPGe is somewhat like averaging 26.8 MPG in a car rated at 25 MPG.
For some reason, much of the discussion of an electric car’s performance is carried out using language associated with gas propelled vehicles (i.e., MPG, MPGcs, MPGe). Seems to me the small distance once can drive on the electric car’s "unit of fuel," the kWh, muddies the discussion. The Electric Mode range difference between the Gen 1 and the Gen 2 Volt, or the Volt and the Bolt, is credited to a difference in fuel tank capacity (i.e., the usable battery size), with little recognition of differences in ev fuel efficiency or other engineering.
That's not a true 86 miles, but looks cool.
21 - 40 of 52 Posts
