How about a rear hatch handle on the left side for we lefties in addition to the one on the right?
At least we have our left hand free to slow down the hatch when the struts fail.How about a rear hatch handle on the left side for we lefties in addition to the one on the right?
And then take steps back to your left to get the stuff out of the cargo area...Not to downplay your frustration in a right-handed world but if you take two steps to your right before using your left hand, it works fine. I tried this after reading your post. Worked for me.
Because there is a simple two-step answer to the problem as BlueStar has tested... with a two-step return as ItsNotAboutTheMoney points out. It's a twist, twist on the Hokey Pokey dance. lolOddly enough this has come up before, without much support. It's such a simple fix I can't understand why it is not done as a matter of course.
Yes, without as much shaking of your tush, unless you really swing that way.Because there is a simple two-step answer to the problem as BlueStar has tested... with a two-step return as ItsNotAboutTheMoney points out. It's a twist, twist on the Hokey Pokey dance. lol![]()
Why are you using that handle to open the hatch?And then take steps back to your left to get the stuff out of the cargo area...
