"Now, here's the rub: Reports suggest the Volt can make it through the EPA test cycle -- which from 2008 includes high speed running, air conditioning load, and cold start tests in addition to the city and highway cycles -- with the internal combustion engine running about 15 percent of the time.
The straightforward calculation gives the Volt an EPA fuel consumption rating somewhere north of 100mpg. But the EPA apparently wants to certify the Volt differently, insisting it finishes the test with the batteries close to full charge. That drops the calculated fuel consumption to just under 48mpg, because the internal combustion engine has to be run to replenish the batteries."
http://blogs.motortrend.com/6293345/government/could-the-epa-cripple-the-chevy-volt/index.html
