Right. There's a setting called "Deferred" outline in the owner's manual that will only turn the engine on below +15F instead of anytime below 35F. You can also disable engine assisted heating while plugged in, and then when you're plugged in it won't turn on regardless of any outdoor temperature (until you unplug, then it reverts to the 15F or 35F setpoints).1. Read the owners manual
2. Follow the instructions to set the minimum threshold for ERDTT (Engine Running Due To Temperature)
Or use the ERDTT air sensor hack mentioned by ZIV, It won't void the warranty, it just adjusts the system to respond at an even lower temperature. See http://gm-volt.com/forum/showthread.php?127761-ERDTT-Modification-Options&p=1758281#post1758281
When Engine Assist Heat is running the Volt will only run the ICE until the engine coolant temperature reaches ~140F/60C then cycle off. The Volt will cycle the gas engine to keep the engine coolant temperature between 120F/50C and 14/60C to be able to provide cabin heat. Unlike Hold Mode, Engine Assist Heat will continue to run the ICE at traffic signals if the engine coolant temperature has not yet warmed sufficiently to provide cabin heat. Engine Assist Heat does generate some surplus power that goes into the battery but the gas engine does not power the wheels the way that the gas engine powers the wheels in Hold Mode or Mountain mode and should use less fuel than either of these two modes.I feel your pain. I knew this would happen when I bought the Volt. but it's worse than I expected. On my normal commutes in the last week, every drive I've done has been within EV range, but about 2/3 of the driving has been done on gas. I'm surprised the car doesn't at least shut the engine down when it's stopped at a traffic light.
1. ? What do you mean? ERDDT is there no matter what you do....1.Just game that engine once in awhile
2. and realize there is no free lunch.
3....good for the soul....!!!
My Gen1 is rolling into its 6th consecutive ERDTT perma-defeat winter now...my how time 'flies'!BTW.
ERDDT is not good for the engine. Running it as a 'Gas Burning Hot Water Heater' and never getting the coolant above 150* F, never burns off moisture in the oil. Go all winter like that and look under your oil fill cap.![]()
^^^ This.When Engine Assist Heat is running the Volt will only run the ICE until the engine coolant temperature reaches ~140F/60C then cycle off. The Volt will cycle the gas engine to keep the engine coolant temperature between 120F/50C and 14/60C to be able to provide cabin heat. Unlike Hold Mode, Engine Assist Heat will continue to run the ICE at traffic signals if the engine coolant temperature has not yet warmed sufficiently to provide cabin heat. Engine Assist Heat does generate some surplus power that goes into the battery but the gas engine does not power the wheels the way that the gas engine powers the wheels in Hold Mode or Mountain mode and should use less fuel than either of these two modes.
The best ways to keep the engine off for these short trips in 15 degree F or lower temperatures are to walk, jog, run, bike, snowshoe, dogsled or cross-country ski to the grocery store.Does anyone know a way of turning it off? I guess it is more efficient when I am going 50 miles but when I am going to the grocery store with a fully charged battery, it seems stupid.
At those temperatures (15F/-10C or below) you would never be able to drive 50 miles on just the battery, probably closer to 30-35 miles, beyond that distance your Volt would be running in CS Mode and using gas anyway.The best ways to keep the engine off for these short trips in 15 degree F or lower temperatures are to walk, jog, run, bike, snowshoe, dogsled or cross-country ski to the grocery store.
It actually seems like the engine is using more fuel during the heating cycle than in Hold mode in warmer conditions, at least while it's running. When I've run in Hold mode it's run around 5l/100km, but currently during the time that it's running it's more like 7-8l/100km.When Engine Assist Heat is running the Volt will only run the ICE until the engine coolant temperature reaches ~140F/60C then cycle off. The Volt will cycle the gas engine to keep the engine coolant temperature between 120F/50C and 14/60C to be able to provide cabin heat. Unlike Hold Mode, Engine Assist Heat will continue to run the ICE at traffic signals if the engine coolant temperature has not yet warmed sufficiently to provide cabin heat. Engine Assist Heat does generate some surplus power that goes into the battery but the gas engine does not power the wheels the way that the gas engine powers the wheels in Hold Mode or Mountain mode and should use less fuel than either of these two modes.
