1 - 4 of 4 Posts
I got this message this morning on the way to work. Made it to the dealer. Once there I shut it down and turned it back on. No power at all. Waiting to hear what the issue is. Hopefully it's covered under Voltec warranty. If not I will be looking another car.
What year is your Volt? I had a similar issue with my 2012. If I remember it probably happened around 2013.
I got message reduced propulsion -engine not available. I pulled off the highway and parked. Tried restarting-no engine just funny noises. Onstar sent a tow. When the tow got there, I was able to start with the engine running. I drove 50 miles to my closest dealer and left it, after hours. They had it for 3 or 4 days. They never found anything wrong with it. It has been fine with these regard since. The story that I got was " it probably a metal shaving from production that got caught in a transmission solenoid, which then probably dislodged hopefully getting caught in a filter"
Maybe you should try restarting after it sits a little while. If that does not work, you should probably at least get codes.
Update: The electronic brain for the transmission has a problem. They are replacing this + the throttle body under the Voltec warranty. Gave me a loaner- new Colorado PU. The Volt (2014) did what it supposed to do. It went into "limp-home" mode and let me get to the dealer- I was still able to do 65 mph. Throttle response was reduced. Once I got to the dealer and shut it down, I restarted it but had no propulsion- which is what is supposed to happen. It will be fixed by EOD tomorrow- 2 days in the dealership. And this was because they didn't have one of the 3 parts needed. Cars has 46,000 miles.
1 - 4 of 4 Posts
