I just had my first EMM since I've been using my OBD to monitor things.
I was under the impression that EMM simply switched to gas mode to get things running, and otherwise normal operation, despite having battery left over. And that any unused power from the engine spinning the generator would go into the battery (provided not full)
Well, in checking the OBD values, it is literally just wasting gas. 0 electricity was generated and stored.
The battery SOC did not increase despite the engine running for ~12 minutes.
In fact, it actually went down faster than if I had just been idling.
Used about 450-500Wh in the 12-13 minutes. (Normal idle draw is that much in an hour)
So the engine is not only wasting gas, it's not even generating the electricity used to run the extra components it needs..
I was parked while running it, but for those who do it while driving, does your battery still get used as you drive? or is it actually using the gas energy to move?
I would hope FMM works like a forced hold mode, as expected, no?
Seems like a missed opportunity for efficiency with EMM to not capture at least some of that energy.
And I'm pretty sure most people would be under the impression that it is doing that, like I was.
