Electric Tri-State? Illinois Tollway looks at embedding charging equipment in I-294
4523 Views 32 Replies 10 Participants Last post by  DMC5180
The Illinois Tollway is examining the possibility of embedding equipment into I-294 that would charge electric vehicles as they drive along the road.
http://www.chicagotribune.com/news/local/breaking/ct-biz-tollway-electric-charging-20180926-story.html
21 - 33 of 33 Posts
The Volt has a gas engine and is not considered as an EV like the Bolt. wssix99 nailed it, the EV license plate makes the Bolt different. So apparently there was a record mismatch in the tollway system. My transponder's "car" designation did not match the EV vehicle license type of "other".
The transponder isn't coded to a plate type. The transponder only corresponds to a vehicle classification, by number of axles. The Tolls are all the same per number of axles, so that's all that matters.
It sounds like your transponder wasn't read once or twice and that you were secondarily video tolled when you went through. When your plate type in the system doesn't match your physical type in real life, the plate doesn't match your account and it gets processed as a violation.
The Volts (and all EV's) have transponder problems and won't have 100% reads like normal cars. So, you'll video toll a lot more in an EV. The Illinois Tollway gives us 5 video tolls a month at the transponder rate (before they kick up to the higher cash rate) to account for these sorts of blips.
The coating in our windshields makes it harder for the tags in the passenger compartment to be read, so there is a Plate Transponder that we can get. (I use one now. I also had the same video toll experience you had.) The Plate Transponders work great in the open road tolling gantries but some of the smaller funnel lanes (and the Skyway) aren't calibrated well for them, so sometimes they will misread and still video toll.
Great info, thanks!
For many years we kept the transponder in the 2011 Volt's cubby on top of the dash (later cars don't have this cubby). Never had an issue until recently. Maybe it was being video tolled the whole time, I don't know. After a spate of non-read penalties (fixed with a phone call) we now keep it on the glass.
Now, what's Wisconsin doing along I-94?
What part of I-94 are you referring too?
Great info, thanks!
I also wonder if the Age of the transponder has something to do with it not being read on occasion.
I got a notification letter from the Illinois tollway office a couple years ago, that said, the transponder was due for replacement based on its age and some internal battery timing out. I’d had that transponder 10 years. The next time I was down that way, I stopped at the Belvedere oasis and exchanged it for a new one.
On a side note, I have a Vehicle with with an IR blocking windshield. The transponder will not work behind that glass. They have those plate mounted transponders to address this issue. However, they are big and ugly IMO.
I took my interior transponder with new Sticky pads and mounted it inside the plastic bumper cover near the center. It works perfectly that way and is a stealth appearance. Also, when I go through the Toll Exits, I always slow down enough to observe the Blue light come ON. Never missed one yet. I use it as confirmation that it still works, since I only go to the Chicago area a few times a year. I’ve seen plenty of people fly through them.
Your’s was due the EV license plate. A state of Illinois thing.
I’m in WI. We don’t have an EV license plate for General class Automobiles. There is a Low Speed Electric Vehicle plate. But those are only issued to NEV’s neighborhood electric vehicles Aka Road-able golf carts.
A Bolt in this state just gets a regular AUTO plate, but has a $100 EV FEE To make up for lost GAS tax collections added too the Standard plate fee of $75.
Yup, and while that's a LITTLE much for me, the gas tax I don't spend is about $60 so it's not THAT far off, and I admittedly don't drive a whole lot. It probably steams up the lead-footed Prius owners, though, who only getting about 35 MPG and are burning gas for every trip...
Since this is the Illinois toll road we are talking about, Chicago to Milwaukee is about a hundred miles, you could do that round trip without recharging in a Model 3 easily, you could even do it in a Bolt if you were careful, and certainly if you had just a little bit of destination charging. Putting a couple of fast chargers on the highway would completely solve that problem.
It's about 60 miles from the Lake Forest (northernmost) Oasis DCFC to the EVGo one at Outpost Foods on Milwaukee's near south side. Even a Leaf could do it with a trivial level of attention. There's TWO SC stations between those points and another just south of where the Oasis is plus a Tesla showroom, so Teslas are well-covered.
I stopped at the I-88 oasis by DeKalb on my Iowa trip to see if any were there yet, nope.
Hah. Road construction. :)
What vehicle are you paying the $100 EV fee on?
It probably was. The transponder reads aren't accurate unless the transponder is up high in the glass away from the dash.
Yea, there is a Lithium Ion battery inside that wears out over time and the Tollway has us rotate the gear out as that battery expires.
2012 Volt. Just like the signature says.
Can’t see signatures when using Tapatalk.
Either way, when I renewed in May, my Renewal fee was still $75. No change.
I will say that the plate was a transfer from our previous Caddy. Not that it should matter the Volt is still registered with a VIN that should tell the DMV what type of vehicle class it is.
They'll figure it out eventually. And bill you for it.
At one time, their was supposed to be a 2-tiered EV fee. $75 for Plug-in Hybrid and $100 for BEV. Which one are you paying ? Or have you even had a 2019 renewal yet, since the law went into effect Jan. 1, 2018?
The DMV only lists (electric vehicle only) fee $100
Here a copied excerpt straight from the DMV website.
[On September 21, 2017, a new law created a $100 annual surcharge for electric vehicles (motor vehicles propelled solely by electrical energy and not capable of using gasoline, diesel fuel, or alternative fuel).
The surcharge applies to vehicles registered as an automobile or as a light truck up to 8,000 lbs. gross weight, including dual purpose vehicles. The surcharge will be collected whenever the regular annual registration fee is paid for plate issuance and registration renewal.
The new surcharge will be collected starting with applications received January 1, 2018, or later.]
My takeaway is that the Volt is capable of using gasoline, so it is exempt. And it states applications received after Jan 1 2018. Meaning new Vehicles or new/used vehicle transfer applications after said date.
21 - 33 of 33 Posts
