1 - 9 of 9 Posts
I was bored this weekend so I decided to find an easy way to make a tool for manually releasing the hatch. This is useful if camping in the Volt or if the 12V battery dies and you need to open the hatch. Others here have used large flat-bladed screwdrivers, and at first I tried that, but I found that difficult to use in practice... you have to line it up just right and it can be tricky when you're crunched in the back (yes, I shut myself in the hatch area to test this all out... in retrospect I should have put the seats down so I wasn't so cramped, ha).
So I wandered the hardware store and came across some screwdrivers with 5/16" square shafts (previous posters have commented that the square release hole is about 5/16"). A few minutes with a dremel cutoff wheel converted the screwdriver into a perfect square tool with a nice grip. Cost about $5.
Cool. It shouldn't be legal to NOT have a quick way to open the hatch from the inside of the vehicle - even if it is a hatchback...
I looked through the manual and can find no reference to opening the rear hatch from the inside. Anyone have pics or a thread for this?
Discussion Starter #5
I don't have other pics handy, but it's easy to see for yourself. Open the hatch and look up near the latch mechanism. There will be a cover around 1"x1" (or smaller). Pry this off and peer inside, you'll see a square receptacle that my tool above fits into to turn it for manual release.
My emergency hatch access tool is both very very cheap, and very very expensive <LOL>
Thanks for this ... creative, cheap and effective ! Just the way I like it (and I have a dremel too). thank you sir !
Well, unlike getting locked in the trunk, you can climb between or put down the seats and open a door. It's a neat tool idea though.
Or, after prying off the lock cover, a wide blade screwdriver will fit diagonally in the square hole. Turn to unlock. I have a short stubby one that works.
1 - 9 of 9 Posts
