I've been searching for a while for the best way to illuminate the rear reflectors on my 2014 Volt. I have ruined 3 reflectors trying to take them apart and add LED strips. It is not only very difficult to do, but it doesn't match the brightness of the OEM tail lights very well.
So, I eventually found what I think is the easiest and best-matching way to get tail/brake lights to the reflectors.
You don't have to take the reflectors apart. Just remove them from the car and drill a 7/8" hole into the middle of the back of the lens, in the middle of the three little holes that are in the back side of the reflector. You are essentially making that middle hole into a 7/8" hole. The only tricky part is setting up the hole saw so that the pilot bit is just barely (1/8" or less) sticking out beyond the saw. Then drill through the back slowly, check where you are, and then keep drilling through the red lens, but no further. Take your time check where you are frequently. The hole saw goes through the plastic very easily, so no real force is needed. When you are done, chip away the edges of the holes, especially the red lens hole, with a little screw driver or a probe, to clean up the cut. Then take a vacuum and hold it to the hole while you shake the reflector around. This gets all the chips out. You can see any chips you missed through the front of the lens. Keep shaking and vacuuming until there are no bits left in the lens.
The light to use is Phillips 3157 LED. It is a very bright red LED stop/tail light. It needs to be modified for our purpose. What you do is cut of the top round section of the bulb. It doesn't do anything, it's just a hunk of plastic. Cut it off flush as close to the little notch as possible (see photo). Then sand it smooth, apply a blob of RTV to the flat surface, and stick the bulb into the hole you made in the reflector. Align the bulb so that the base is vertical, up and down, NOT horizontal. The LEDs are at an angle in this bulb, and shine down onto the reflective surface inside the reflector, which is what makes the light look so close to OEM. There will be a gap between the bulb and the hole, which I covered with reflective aluminum tape.
You will also have to drill a 7/8" hole through the hatch where each reflector mounts. Again, easy to do, but make a template of your modified reflector so you get the hole in exactly the right place.
The 3157 has separate running light / brake light, both 12V, so it is easy to wire. Use a 12V source to identify the 4 pins on the bulb base. 2 of them are marked +, so the other two are grounds - touch the +12V to each of the 2 + pins and you will find which is the brake and which is the tail light. Mark the brake light + with a sharpie or something. The grounds don't matter - they will be connected together anyway. You could buy a 3157 bulb socket for ease of wiring, but I just soldered my wires directly to the bulb pins.
Install the reflectors back on the car.
Now connect the 2 brake lights from the reflectors together and the 2 tail light wires together, and run a single brake light wire and the single tail light wire to the plug in the left side trunk compartment. Ground the wires from the bulb grounds at the hatch latch plug connector black wire.
There are lots of threads here about how to run the wiring and where the brake light and tail light wire connections are, so I won't go into those details.
Some photos of the result:
[video]https://i.imgur.com/06W2c6U.mp4[/video]
Best Regards,
e
Best Regards,
e
