Folks,
I've found that the Bolt EV uses Dexron HP (Dexron High Performance, I believe) for the gearbox - about 3 quarts. And, GM makes no mention of needing to ever change it.
Would it be a good idea to put a few thousand miles on the car, then change this fluid out for a fresh fill of Dexron HP to get rid of material left in the manufacturing process?
(I'm asking because over in Priuschat, it's considered a good idea to change the transmission fluid early, and then about every 60 miles or so. I'm wondering if it applies to the Bolt too).
